I acquired it from Marktplaats in the Netherlands and was in working order when I shortly tested it at the seller.
At home and experimenting with it, it gave a popping noise within 10 minutes and my study filled with smoke and the smell of burning cardboard. I now know I am quick at switching off and unplugging.
On the power-PCB I found an exploded power capacitator, just like Mad Maxwell describes on his blog. But I also found a couple of suspect diodes and another capacitator in combination of suspect pcb-traces which I all replaced with new components and insulated wiring. After reassembly I switched on the oscilloscope and immediately was met with a wihstling noise like steam leaking from a tiny hole. Off course I switched the thing off right away.
The last suspect is the huge transformer; it seems to have been overloaded since the sides seems to bulge out. Replacement seems in order.
Unfortunately, I can not find a usefull reference or identifier with which I can buy me a replacement. Do you, fellow-boardmebers, have any suggestions?
The sticker on top reads: 4022 369 68093 DY 071
The manual refers to part # T1801 (Ordering number 5322 148 84039).
According to the schematics it is 220V in and -6V / +6V / -12.7V / +12.7V / -60V / +60V / 1000V / 1500V out
Any help/suggestions will be highly appreciated.
Kind regards,
Bob
PS. A picture of this transformer is found on Maxwell's site but reads a different DY number.
[/url]
